Stock Pull-Down selector - lose mouse arrow
This is weird ...
I'm using the stock pull down menu selector in a project.
The first time it happened, I thought problem with .... something ...
But it has happened several times now.
The 'menu' is setup to selected a MIDI CH 1-16. After I select a channel ... the mouse arrow disappears !!
By fishing around with no arrow on the screen, I've been able to close FS. But I'm going to check the SM selector to is if the problem persist.
Anyone else have this happen ???
OF COURSE .... now that I'm checking it again ... it's working ... but believe me ... it has been disappearing
Re: Stock Pull-Down selector - lose mouse arrow
Yep ... doing it again.
If I go inside the schematic ... the selector works as expected.
BUT ... from my main GUI window ... the arrow goes away when I click on the selector. I can still select a channel,
but the cursor arrow is gone. [only inside FS].
Now ... this GUI window is a 'hidden' window that I push a button to call up. Some how this is messin' with the mouse
sorry for multiple posts ...
I switch pull down menus using the stock SM selector.
Everything works ... mouse arrow does NOT disappear.
Something is up with the FS selector ... that one is RUBY based.
