preset manager limitations
Postby tester » Thu Sep 05, 2013 4:16 pm
I'm starting to wonder where is the borderline of performance for preset manager.
Just did a little test with preset params to common string conversion and here are some thoughts.
at 2400 parameters to store: 40 seconds loading time
at 1400 parameters to store: 10 seconds loading time
sound offline.
Under test:
1) It is better to do more smaller "preset string" modules than less and larger ones. I mean it. When preset string deals with 40-80 switches, then arrays update start to play signifficant role. I suspect a good thing is around 10 switches per array->string. Then you can resign from manual retriggering for "store and load preset values"; just need to use "changed" to limit amount of updates (array, value reload).
2) It's good to use "preset string" routine/conversion only for static values and switches only. They change only on user interaction, and it means - the array change, not only the single value.
Now it's time to push inside some streamy guts to add blue load on preset routines.
//edit: works under load too.
Ehm.... in a few days back to the old project again :-D
tester
Users browsing this forum: No registered users and 71 guests
