float value from poly
Re: float value from poly
Postby TeslaTronik » Fri Jul 14, 2017 7:12 pm
Thanks for trying though bill, i'm somewhat stuck on FlowStone 3.0.9 BETA1 as i'm not eligible for beta 2 from when i bought Flowstone... And because i started my project (its big and messy) in this version when i try and load it in older versions it wont work.. so i guess i'm stuck with it.
@Spogg, unfortunately i can't open your Schematic as your version is newer, however, Adam is indeed correct, the behaviour i'm after is as he suspects and the behaviour i get is not in keeping with lets say "serum" or any other VSTi with this type of ~"knob modulation".
I appreciate all the help from you guys, its good to see this forum still has visitors and people are still using FS.
@Adam, i'm guessing this new max-to-poly as a primitive will not be usable in FlowStone 3.0.9 BETA1?
TeslaTronik
Postby lalalandsynth » Fri Jul 14, 2017 7:37 pm
Have you tried exporting as vst yet ? 3.09 has all kinds of problems for me , even on the simplest stuff.
Check if it leaks memory as an exported vst .
lalalandsynth
Postby TeslaTronik » Fri Jul 14, 2017 9:34 pm
I have exported it as a vst a few times for testing.. it seems o.k asides from some cpu spikes here and there.. but they could be attributed to the way i "stick" my projects together. i did not think to look for a mem leak though so will test that out asap.. Thanks for letting me know that issue.
TeslaTronik
Postby adamszabo » Sat Jul 15, 2017 3:45 am
The 3.0.9 betas that you guys have access to are kind of old, and there are lots of new (private) betas or alphas i dont know what state it is in. But hopefully those new betas will be released soon and you can all try out my method which i suggested.
adamszabo
Previous
