Downgrade Software
Downgrade Software
Postby adickalvidi » Fri Feb 17, 2023 9:37 am
Hello FlowStone-Frends,
I created several projects with V3.0.9 Beta 2. Actually this version contains many bugs, so I diceid to switch to the old version V3.0.8.1
is it possible to open/edit my projects with old versions?
Thank you very much in advance.
adickalvidi
Re: Downgrade Software
Postby martinvicanek » Fri Feb 17, 2023 5:36 pm
Unfortunately, you cannot open V3.0.9 Beta 2 schematics with older FS versions. It is a dead end road. :(
If you have code boxes, you can copy and paste the contents of course, but that's about it. Everything else has to be rebuilt manually.
Postby Spogg » Sat Feb 18, 2023 9:41 am
Fortunately I was eventually able to get Malc to remove the 3.09 betas from the download section, so nobody else new will fall into this trap.
