Trouble with example[Solved]
Postby alexalthauser » Tue Jan 22, 2013 9:56 pm
Having trouble recreating the example from the manual. I enabled the mouse move messages on the mgui. The cursor changes when it moves in the window, but no coords are printed in the ruby console.
Last edited by alexalthauser on Tue Jan 22, 2013 11:00 pm, edited 1 time in total.
alexalthauser
Re: Trouble with example
Postby support » Tue Jan 22, 2013 10:04 pm
Looks like you have the V input as the second one down, the default is for the top one, otherwise you have to address it properly.
support
Postby alexalthauser » Tue Jan 22, 2013 10:15 pm
Yes, I actually tried that right after I posted, it still doesn't output the coords from the window. However, I did hook it up to the mgui, and it returns coords when I mouse-over that module.
alexalthauser
Postby trogluddite » Tue Jan 22, 2013 10:48 pm
I think that the extra "external" MGUI may be confusing things.
The boolean "true" for the mouse_over has to be connected to the MGUI that's inside the display window - setting mouse-over true for one MGUI won't also set it for other ones, as they are being shown on different areas of the screen.
That got it working here, anyway - hope it helps.
Postby alexalthauser » Tue Jan 22, 2013 10:59 pm
That was it. I thought it was an upper level switch, which would set the enable mouse moves to true for all components connected to it. Your way makes much more sense, though. Thank you.
alexalthauser
