double point slider
double point slider
Postby kortezzzz » Mon Mar 04, 2019 5:12 pm
I try to make a slider with 2 moving points that can cut the scale between 0 to 10 into 3 different areas. Both points should move forward and backward indeed and they should limit each other at the max and min points. For instance, if the right point is set to 6, the left point can't pass it. making it in green is a headache. Maybe Ruby can help here? Attached a picture for demonstration
https://imgur.com/cmSUqia
kortezzzz
Re: double point slider
Postby billv » Mon Mar 04, 2019 11:35 pm
Here's a double slider I made a while back.
Hope it helps or gives you an idea of how to do it better. :|
Double slider_BV.fsm
(23.62 KiB) Downloaded 828 times
Postby kortezzzz » Tue Mar 05, 2019 12:18 am
Boom! Awesome.Thanks a lot billv :)
It works nicely here. Any chance that each of the three zones gets it's own color, instead of transparent background in area A and C?
kortezzzz
Postby RJHollins » Tue Mar 05, 2019 1:18 am
Nice stuff BillV 8-)
Users browsing this forum: No registered users and 38 guests
