Is there a TCP/IP stack
Postby vostryc » Thu Dec 23, 2010 8:43 am
Is there a TCP/IP stack/software module/component in the works ?
Many of us need to monitor/control things over the web.
Or did I miss this ... in the Doc's ?
Tks,
vostryc
Re: Is there a TCP/IP stack
Postby Embedded » Wed Dec 29, 2010 10:30 am
There is a TCP IP module in FS Pro.
The data coming out of the TCP module is Strings, so if you need to buffer the data you can use the String Stack component.
This works really well on a LAN or over the web!
Embedded
Postby Drnkhobo » Sat Oct 06, 2012 10:50 pm
Hey where is this module located?
ive got FS pro & I cant seem to find it?? :cry:
******WAIT*****
Found it uder 'Network Client' module
:oops:
Drnkhobo
cron
