converting small thing into ASM
I just found another piece, that could save (very little but some) CPU due to need of reusing pack/unpack on the go. How to convert this one into mono4 single ASM piece? (Multipliers are used instead of selectors/multiplexers to avoid code resets on switch; I guess this one is not doable in code due to different operations on channels?). Correct me if I'm wrong (i.e. if there is no benefit from such conversion).
leds.fsm- (2.13 KiB) Downloaded 887 times
- tester
Re: converting small thing into ASM
This one only works with the first 2 channels of packed mono. The other 2 channels are overwritten, by a copy of the first 2.
leds (MyCo).fsm- (2.41 KiB) Downloaded 898 times
MyCo - Posts: 718
Thanks!
Good learning tool for getting some basics on the go.
- tester
