Potential COM Port Module Bug
Postby manton » Tue Jul 16, 2013 6:08 am
I just noticed that the list of ports on the COM Port module includes COM0. Can anyone think of why this would be, since AFAIK COM0 is not allowed, and numbering usually starts at COM1? I know that my machine certainly does not have COM0 available.
I'm using V3.0.2.
Thanks.
manton
Re: Potential COM Port Module Bug
Postby jjs » Tue Jul 16, 2013 10:31 pm
since win XP every com nr is allowed, even if you not have them as a hardware port.
indeed virtual ports !
jjs
Postby manton » Wed Jul 17, 2013 12:35 am
But, in my case, I don't have a real or virtual port on COM0, at least according to device manager.
Thanks.
manton
Postby jjs » Wed Jul 17, 2013 6:55 pm
Can be.
If your motherboard does not have one, or you turned it off in the BIOS
on the other hand virtual com ports are often installed by some kind of software and like usb to rs232 cables. Then you can set any com port you want in the device manager
jjs
Postby manton » Sat Jul 20, 2013 12:11 am
Well, I don't know about your machine, but on mine I cannot set any ports to COM0. Every other number from 1-255 is available though. So, I still suspect that COM0 is not allowed.
So, I repeat, given that I do not have a COM0 on my machine (and couldn't map one to it even if I wanted to), why does the COM port object have COM0 in the list of available ports?
manton
Postby MyCo » Sat Jul 20, 2013 1:00 am
Serial Ports can have any name, not only "COM"... FS only supports serial ports that start with "COM", all other ports are wrongly mapped. I don't know the exact code in FS, but I think they do it like this:
1. Get the names of the serial ports
2. Remove the first 3 characters from the names
3. interpret the remaining chars as integer
So, if you have a serial port that hasn't an integer after the third character, this will propably be read as "0".
You can test this with other terminal programs that support any names for serial ports, eg.:
http://www.der-hammer.info/terminal/
I've seen this com port issues before (and already notified the Devs about that), because I've virtual com ports on my PC that have names like "CNCA 1", "CNCB 1",...
MyCo
Users browsing this forum: No registered users and 38 guests
