MidiVst should have"FLStudio"in its menu but it's missing
Postby Matth23u » Tue May 07, 2019 6:04 am
My VST shoudl have "FL STudio" in it's midi input and midi output menus, but it'S missing, making the plugin impossible to use as a VST.. But only as a synthmaker plugin...
I guess i'd rather host the file myself so i don't just use too much space on your server.
nightmaredream.com/up/MidiDroneDemo.zip
Say... It should display FL Studio as in and out so i can use it to alter midi. I had an older thread about it but i guess both topics are unrelated because it's about an exported VST this time...
I still encounter certain c++ crashes which gets a bit problematic, forcing me to reboot the software.
I'll try trogluddite in the other topic related but unrelated...
Maybe should i just make a thread called "development journal of "mididrone" or something...
Anyway. I'll keep organized and link to other threads.
And somebody else is making some plugin that is very promising so i'll try to see if we could somehow collaborate or something.
viewtopic.php?f=2&t=16603
viewtopic.php?f=4&t=15955
Also, i still have crash when clicking the folder "packs" which contains the module pack from the module pack thread...
viewtopic.php?f=2&t=16604
Matth23u
Re: MidiVst should have"FLStudio"in its menu but it's missin
Postby adamszabo » Wed May 08, 2019 8:47 am
FL Studio is not a midi device so you will not see it listed. When you export your project as vst you can still use it inside FL Studio
adamszabo
