videostream
videostream
Postby csdsp » Sat Mar 05, 2011 11:59 am
I need a video player without the name of file visible, but i think it's impossible with videosteam?
csdsp
Re: videostream
Postby csdsp » Wed Mar 09, 2011 8:45 pm
ok i'm french with a bad english, sorry
Flowstone use vlc and is possible to take a command for this, but if is in a primitive videostream i don't try a entry for command. So it's really impossible or i don't think a good issue?
Thanks for your reply i've 5 days for change program if it's impossible.
regards
csdsp
Re: videostream
Postby Embedded » Thu Mar 10, 2011 11:24 pm
Yes you are correct FlowStone uses the VLC engine to playback the video. The name of the file on my system only appears for a couple of seconds at the beginning, you could always hide the video image for two seconds until it is gone if it a problem for you.
Another option might be to see which dll from VLC plays the title and delete it from you system!
Maybe the title thing could be an option in future versions of FlowStone.
Embedded
Re: videostream
Postby csdsp » Sat Mar 19, 2011 8:55 pm
hi,
after a uninstall two version of vlc in my computer, make a clean and reinstall vlcdll all is correct and it's possible to play video in flowstone without name of file. I réinstall vlc in my computer and it's always correct ???
BUT, now i command vlc in external because i want a fullscreen and after many many test of shematics, codecs and resolution for a file play with external vlc i use 5% of process and for the same i use 60% of process in flowstone ???
csdsp
Users browsing this forum: No registered users and 80 guests
