server issue
server issue
hi,
A new stange problem:
I work with a configuration with different server and client and i make a application with server all work fine i make exe all work fine i use the exe in another pc and it's impossible to open the server i install flowstone in this pc and the server work fine with the fsm i make exe and the server don't work i test with different PC and i don't understand why sometimes it's ok and sometimes not.
all with win pro 32
I test uninstall all uninstall the network, reinstall all and nothing. Strange strange strange for two pc with correct fonctionnality with flowstone or with exe after different test it's now impossible to open a server with exe.
all with win pro 32
- csdsp
Re: server issue
it has already been reported here.
At the moment it doesn't work
- sal
Re: server issue
It looks like this has been fixed in the new release:
http://www.dsprobotics.com/support/viewtopic.php?f=22&t=191
- Cat5
Re: server issue
I've make a big install with 1 computer listen 6 others with 6 different ports. Because this install turn between one week i used a java server and also flowstone client. I've test this day change my 6 clients by 6 flowstone server without Java server and i have a strange disconnect sate. I've make a reopen function but after few test i've return with a java server. I'm not sure but it's possible for me to make change in one week and be sure server work fine.
- csdsp
Users browsing this forum: No registered users and 80 guests
