Modeling an Guitar Amp
• Page 2 of 2 • 1, 2
Re: Modeling an Guitar Amp
Nice Links !!!
However is the Synthmaker site down?
Aron
Aron
aronb - Posts: 154
aronb,
SynthMaker site has been down (off-line) off and on in recent history, however, it has been down for several days in a row now, possibly removed permanently which is too bad because there was lots of good info and modules there.
-acg2010
-acg2010
- acg2010
acg2010 wrote:Guto, I am no expert and not even a guitar player myself but if you search the SynthMaker forums, there is a lot of good info on distortion and guitar amp sim info. My guitar amp sim project is here if you want to take a look at it:
viewtopic.php?f=4&t=1435#p5781
viewtopic.php?f=3&t=1654#p7484
It has been difficult to get direct help from people who actually create amp sims since they typically don't want to give up any programming or approach secrets. I spent a lot of time reading every thing I could about real guitar amps and cabinets on the internet and other sources to try and understand how they function to be able to try and model an amp. My project is just standard modules and some user created modules found on the forums. I also had a lot of help from people such as Trogluddite, Billv, and others here on the forums.
A good place to start on a guitar amp is to look at ways of creating distortion (waveshaper, gain, tangent functions, etc.). Then look at adding harmonics (odd, even). I found I needed a cab sim to tone down the higher frequencies generated by the amp.
Hope this helps some.
-acg2010 aka Ph D(J) Music
I will once I figure out what I'm doing. So far I created a cool metal distortion pedal vst.
Industrial music isn't dead.
- jesterstudios
acg2010 wrote:Here are some of the relevant SynthMaker forum links I was referring to. This is just from searching for "guitar amp". There are other links if you search for distortion, guitar amp sim, etc. I didn't have anything better to do this Sunday, so I spent time listing the links here in case anyone else was interested. The Bold line is the topic and the link for that topic is below it.
Differential DC Bias Adjust synthmaker implementation
http://www.synthmaker.co.uk/forum/viewt ... amp#p92318
HELP! Guitar amp style knobs
http://www.synthmaker.co.uk/forum/viewt ... amp#p87653
Emulating a Germanium PNP Transistor in Synthmaker or Flows
http://www.synthmaker.co.uk/forum/viewt ... amp#p92033
Comma delimited file parsing
http://www.synthmaker.co.uk/forum/viewt ... amp#p91600
Guitar Amp Sim
http://www.synthmaker.co.uk/forum/viewt ... amp#p89019
using (FL)Synthmaker to make a guitar amp plugin
http://www.synthmaker.co.uk/forum/viewt ... amp#p82356
D plugins
http://www.synthmaker.co.uk/forum/viewt ... amp#p80685
Oversampling Toolkit
http://www.synthmaker.co.uk/forum/viewt ... amp#p45132
Guitar Preamp EXAMPLE for SM People
http://www.synthmaker.co.uk/forum/viewt ... amp#p71039
Guitar Amp
http://www.synthmaker.co.uk/forum/viewt ... amp#p67280
Shred 1.06 Released
http://www.synthmaker.co.uk/forum/viewt ... amp#p65002
RevolutionZ Head Amp
http://www.synthmaker.co.uk/forum/viewt ... amp#p61186
need help learning SM basics
http://www.synthmaker.co.uk/forum/viewt ... amp#p60850
Amplifier Simulation?
http://www.synthmaker.co.uk/forum/viewt ... amp#p10019
How to make a Guitar Amp?
http://www.synthmaker.co.uk/forum/viewt ... amp#p59799
Drive
http://www.synthmaker.co.uk/forum/viewt ... amp#p57536
Who knows C++ Really Good/SM language really well?
http://www.synthmaker.co.uk/forum/viewt ... amp#p53775
Skin
http://www.synthmaker.co.uk/forum/viewt ... amp#p53653
What is causing these denormals
http://www.synthmaker.co.uk/forum/viewt ... amp#p53165
"My Instruments Guitar Bass Effects and Creations of Fun"
http://www.synthmaker.co.uk/forum/viewt ... amp#p52700
Need help with Float Array from disk
http://www.synthmaker.co.uk/forum/viewt ... amp#p52497
Credits for Guitar Amp
http://www.synthmaker.co.uk/forum/viewt ... amp#p52369
5 Cyborgs bass guitar amp simulator
http://www.synthmaker.co.uk/forum/viewt ... amp#p48762
simple distortion
http://www.synthmaker.co.uk/forum/viewt ... amp#p21851
Amp Distortion
http://www.synthmaker.co.uk/forum/viewt ... amp#p18271
Thank you for posting these links. I really have been researching online for information to build my vst.
- jesterstudios
@jesterstudios - unfortunately the SynthMaker forums no longer exist. So all my guitar amp stuff links pointing to that website no longer work. However, if you search this forum, you will find people have archived the Synthmaker forum, modules, schematics, and materials that can be downloaded and searched. Good luck with your project.
- acg2010
Users browsing this forum: Majestic-12 [Bot] and 20 guests
