Controlling automotive injectors...
Postby FluxCapacitance » Sun Feb 02, 2014 3:07 am
Is there a hardware configuration ideally suited for controlling automotive injectors using flowstone? I'm looking at being able to run and control them at 1000 RPM or less.
Is flowstone a better option (since I'd rather program visually)?
Thanks!
FluxCapacitance
Re: Controlling automotive injectors...
Postby jjs » Sun Feb 02, 2014 5:47 pm
since you probably will be using Solenoids or steppermotors(rs485), you could be strating with the solutions and interfaces on the robotics site, link is under PARTNERS at the top of the screen.
With an interface you could start and experiment as cheap as possible.
jjs
Postby nix » Mon Feb 03, 2014 2:13 pm
You may be limited by FS clock speed on green connections.
It is a steady interval at max 1000hz.
I hope this is fast enough.
A Ruby trigger cannot really exceed this speed by very much
nix
Postby FluxCapacitance » Sun Feb 23, 2014 3:20 am
Thanks for the help. I'll have to check it out.
FluxCapacitance
