Need help choosing skin (Black & White)
Black
http://s27.postimg.org/hrhd528wj/Black_Skin.jpg
White
http://s27.postimg.org/budho8rrn/White_Skin.jpg
What skin is the best wich one should i use?
White
- djbrynte
Re: Need help choosing skin (Black & White)
Why not have colour as a user option
- Xtinct
Because it will be pretty much work and alot to change. I mean like will be huge work and bigger size on synth.
- djbrynte
I design my own synths and I dont think its that much to change. you can attach both skins, connect them to a simple selector with 2 radio knobs that will switch between the two and connect the selector to the gui primitive with a redraw. thats it. very simple. if you need a schematic of this approach, i'll post it.
by the way, they are both looks great (as i said in the other post) but i think you should make a nice frame around
the whole synth that will give it a smoother look. if you like the idea, i can help with that to.
kortezzzz - Posts: 763
Sure you can help me if you want to.
- djbrynte
Here is a little schematic that shows how to add into your synth 2 skins (and you can add as many as you want).
hope its helps. i will edit your skin tomorrow and will send it to you.
