path splitter/maker
path splitter/maker
Postby tester » Sat Jun 14, 2014 3:43 pm
I think I remember, someone asked about such tool some time ago.
Path splitter/maker for component management. It takes source path (for example from loading file dialog box) and creates a folder with sufixed files. Can be used to provide destination path, next to the source file when saving output. File extension can be provided externally.
path-splitter.fsm
(700 Bytes) Downloaded 655 times
Re: path splitter/maker
Postby tester » Sat Jun 14, 2014 4:52 pm
I just noticed weird thing. When exporting wave files in this way - FS seems to create folder, but no wave file. It exports wave after folder is created, so I guess there is some internal problem with order.
So here is a quick fix. Trigger creates the folder on first place, and the process is started. Tested, works.
path-splitter-001.fsm
(780 Bytes) Downloaded 649 times
Users browsing this forum: No registered users and 81 guests
