mouse over boolean output ruby?
hi all, just have a quick question, what's the easiest way to output a mouse over boolean in ruby?
i just used this
but isn't there an easier way?
i just used this
def isInMouseArea (x,y,area)
x1, y1 ,x2 , y2 = area
x2 += x1
y2 += y1
x.between?(x1,x2) && y.between?(y1,y2)
def isInMousePoint(x,y)
if isInMouseArea(x,y,@area)
output 'mouseOver',true
return true
output 'mouseOver',false
return false
Nubeat7 - Posts: 1347
Re: mouse over boolean output ruby?
Only another way, but not easier. You could activate mouse move on the mgui prim and in ruby then use
(Pseudo Code)
(Pseudo Code)
def mouseMove x, y
if (you're area code) then output true else output false end
thanks tulamide,
another question, does there exist a fast way to get the view area? something like "getViewArea" ? or do i need to use getViewSize for it..
The latter. Unfortunately, no position offset is returned by any method I know of. It's always local coordinates (Top-left corner will always be [0, 0], no matter where that view is positioned within its parent.
I don't know where your question leads to, but here are some tips.
4-element-array building from getViewSize:
4 objects assignment:
area = [0, 0] + getViewSize
area = Array.new(2,0) + getViewSize
area = 0, 0, getViewSize
area.flatten!
x, y, w, h = 0, 0, getViewSize[0], getViewSize[1]
There's also the splat operator ('*'), which converts an enumerable to an argument list.
view_area = 0.0, 0.0, *getViewSize
- TheOm
thank you, tulamide and om, so many ways to do one thing, good to see this different ways
Users browsing this forum: No registered users and 98 guests
