Bool Help Please
Bool Help Please
Hello Gang,
Again I need a little help! Why does the 7 input (or lower) AND gate work, but 8 or more inputs do NOT. This is probably something really simple , yes?
At this time I need the 8 input AND gate to work for me.
Many thanks in advance!
Later then, BobF.....
- BobF
Re: Bool Help Please
It is a limitation of the DSP code - you can't have more than 8 operations in the same line. It is explained in the manual... Just put few parentheses between the and statements.
- KG_is_back
the reason for it is that the dsp code gets translated to assembler code where it produces a lot of (often unneeded) register movings
connect a text primitive to the "c" output of the dsp code primitive and you will find
make the parentheses KG assumed and watch again, now only the registers from xmm0-xmm7 are used and it works
further you can copy the text code into an assembler code primitive and optimize it, there you can get rid of the most movaps and end up like this
with this version of the code you can add as many inputs you want with just appending the
if the chain is very long it maybe would make sense to use more registers to check up to 7 groups in parallel for faster processing.
movaps xmmB,xmmA
xmm999
streamin in1;streamin in2;
streamin in3;streamin in4;
streamin in5;streamin in6;
streamin in7;streamin in8;
streamout out;
float F1=1;
movaps xmm0,in1;
andps xmm0,in2;
andps xmm0,in3;
andps xmm0,in4;
andps xmm0,in5;
andps xmm0,in6;
andps xmm0,in7;
andps xmm0,in8;
cmpps xmm0,F1,0;
movaps xmm1,F1;
andps xmm1,xmm0;
movaps out,xmm1;
streamin inX;
andps xmm0,inX;
Nubeat7 - Posts: 1347
Users browsing this forum: No registered users and 75 guests
