How can I make persistent ruby data within plugin?
Postby Nowhk » Tue Nov 10, 2015 11:11 am
I create an array and I randomize its value using a ruby function:
def init
   @lfo_size = 100
   @lfo_shape_1 = Array.new @lfo_size
def event i, v
   if (i == "start")
        # somethings
   elsif (i == "random")
        randomLFOs
def randomLFOs
   for i in 0..@lfo_size
      @lfo_shape_1[i]=rand(100)
Once I create it, I'd like that every time I edit ruby script (recompile) or I close/reopen the project/plugin, the array stay persistent. So I work on the same values every time.
Once I re-random it, it recreate the array and store the new one. How this is possible in ruby? In Kontakt scripting for example I use make_persistent(myArray).
Is there somethings similar in FlowStone?
Thanks!
Nowhk
Re: How can I make persistent ruby data within plugin?
Postby KG_is_back » Wed Nov 11, 2015 2:16 am
You can use saveState and loadState methods to store values. it is described in the manual. However, I'm not sure if it will do what you are looking for
Postby Nowhk » Wed Nov 11, 2015 12:49 pm
KG_is_back wrote:You can use saveState and loadState methods to store values. it is described in the manual. However, I'm not sure if it will do what you are looking for
Uhm yeah, it seems to works pretty nice:
def loadState v
   @lfo_shape_1, @lfo_shape_2 = v
def saveState
   [@lfo_shape_1, @lfo_shape_2]
Why it shouldn't works? Thank you!
Nowhk
Users browsing this forum: Google [Bot] and 62 guests
