Sound Card detection?
Postby bradnorwood » Thu Dec 15, 2011 7:49 pm
How can I detect my sound card to control volume using flowstone?
bradnorwood
Re: Sound Card detection?
Postby sal » Thu Dec 15, 2011 8:42 pm
you have to load asio and/or direct sound modules then you can use the audio selector module to select the proper audio card
sal
Postby bradnorwood » Thu Dec 15, 2011 11:16 pm
where and how do I load them? I added ASIO and the wrench icon would not open?
bradnorwood
Postby sal » Fri Dec 16, 2011 1:16 am
the wrench can be used to open the asio control panel of the selected audio card, but an audio card must be selected first.
If you don't see your audio card listed inside the asio module, it's because your card doesn't have asio support, so you should use the direct sound module or install asio for all driver from here.
I have attached a project to look inside.
audioselect.fsm
(2.5 KiB) Downloaded 1267 times
sal
