Download does not unpack
Re: Download does not unpack
I am also having troubles downloading FlowStone FREE. After about 10M it says that the download has been interrupted. Also tried with the link that you gave below. Please advise, thanks.
- dieram
Just tested it from here and it works fine. So it must be something at your end?
A few things to check:
a) have you enough disk space on C: (even if you save it else where it always downloads to C first then transfers it over)
b) Is your virus checker blocking it?
c) Do you have administrator rights? Sometimes this can block downloads.
d) Is your internet connection ok, is your wifi dropping out?
Support: you could always email support, they are very helpful and may send you the file?
info@dsprobotics.com
- DSP
Users browsing this forum: No registered users and 45 guests
