Installation trouble
Postby tor » Tue May 03, 2016 8:46 pm
I have set up an old laptop to use Win XP 32bit. I have SP 3 installed but when I install FlowStone 3.09 Beta i get this error when I try to run it: C:\Prog.....\FlowStone.exe is not a valid Win32 aplication.
I tried to uninstall and install any other versions but when I run them I get this error: The application failed to initialize properly (0xc0150002)
Any help to resolve is greatly appreciated :)
tor
Re: Installation trouble
Postby billv » Tue May 03, 2016 10:23 pm
Is there a Microsoft redistributable present on the machine...?
FS wont run without it...happened to me a few times.
Postby tor » Tue May 03, 2016 10:54 pm
Visual C++ Redist 2015 (x86) 14.0.23026, is installed.
tor
Postby tor » Tue May 03, 2016 11:10 pm
Now also Redist 2013
tor
Postby billv » Tue May 03, 2016 11:27 pm
If still no luck and your desperate...try the 2008 version
Postby tor » Tue May 03, 2016 11:35 pm
I have earlier experienced that Windows Update was not working in Windows XP any more. So when I installed with SP 3 I just disabled automatic updates. Now I thought I'd check Windows Update just in case. Wow, over 140 updates downloading now. I hope this will do the trick.
Will let you know. Thanks for the help :)
tor
Postby tor » Wed May 04, 2016 2:02 am
I have now installed all updates and thinkable Windows extras but I still get: C:\Prog.....\FlowStone.exe is not a valid Win32 aplication, on the 3.09 Beta 2.
Though, now I managed to get the 3.08.1 to install and run properly.
I guess the latest beta is built on a newer OS than XP and thus is not compatible.
tor
Postby RJHollins » Wed May 04, 2016 2:07 am
I thought the beta NEEDED an early version to be valid ?? not sure
Postby billv » Wed May 04, 2016 2:17 am
Glad you up and running in some way.. :D
Users browsing this forum: Google [Bot] and 31 guests
