Trigger Switch in Ruby?
Postby adamszabo » Sat Jun 04, 2016 11:46 am
Hey guys, I am just wondering is there a way to replicate the behavior of the green "Trigger Switch" in ruby? So basically I have two inputs, a float and a boolean true/false, and the events only get triggered/sent, when the boolean is true. I am thinking something like this but ofcourse it is wrong:
def event i,v
      if == 'knob' & @bool = 1
          output 0, @knob
Thanks!
adamszabo
Re: Trigger Switch in Ruby?
Postby Tronic » Sat Jun 04, 2016 12:04 pm
def event i,v
      if i == "knob"
          output 0, v if @switch
Tronic
Postby adamszabo » Sat Jun 04, 2016 12:07 pm
ah, thank you very much! :geek:
adamszabo
Postby Tronic » Sat Jun 04, 2016 12:16 pm
this version output the knob value when the switch become true or the knob is moved when the switch is true
def event i,v
      if i == "knob" || "switch"
          output 0, @knob if @switch
Tronic
Postby adamszabo » Sat Jun 04, 2016 12:34 pm
I forgot to ask, does this actually prevent the calculation when the switch is off, or it simply blocks the values but it still calculates the knob event? So lets say I have something like this:
def event i,v
      if i == "knob"
         @a = some very big and complicated formula
          output 0, @a if @switch
The point is to save cpu when the switch is off, so the even doesnt calculate the stuff inside the code.
adamszabo
Postby Tronic » Sat Jun 04, 2016 2:28 pm
add all your code, in the "if" check block
def event i,v
      if i == "knob"
          if @switch
          # this block of code is executed only if switch is true
              output 0, @a
Tronic
Postby tulamide » Sat Jun 04, 2016 2:43 pm
Tronic wrote:add all your code, in the "if" check block
def event i,v
      if i == "knob"
          if @switch
              output 0, @a
I would reverse it, since there is no need to even check for 'knob' if switch is false:
def event i,v
      if @switch
          if i == "knob"
              output 0, @a
or, if the event method as a whole is just executed on knob and switch:
def event i,v
      if not @switch then return end
      if i == "knob"
              output 0, @a
Postby Tronic » Sat Jun 04, 2016 3:37 pm
tulamide wrote:I would reverse it, since there is no need to even check for 'knob' if switch is false:
def event i,v
      if @switch
          if i == "knob"
              output 0, @a
yeah, but this not update the output value when the switch is true and the knob is not moved,
but it has been moved previously.
But of course, it depends on your use.
def event i,v
          if @switch
          # this block of code is executed when the switch is true
          # or the switch is true and knob moved
              output 0, @a
Tronic
Postby tulamide » Sun Jun 05, 2016 12:10 am
Tronic wrote:yeah, but this not update the output value when the switch is true and the knob is not moved,
And that is the same behaviour as of the trigger switch, and it was asked for that behaviour. But sure, if you need a trigger on true, even if the knob doesn't change, then my proposal won't work.
Users browsing this forum: No registered users and 57 guests
