better db to linear 0-1 (especially array)
Postby wlangfor@uoguelph.ca » Tue May 19, 2020 8:41 pm
most methods involve using code or asm and that's not as efficient as this. I was working ona metering solution for My boardstation EQ and came up with this, so as to avoid any zero's. It's as close as you can get to -INF
First, send the signal to a nan to 0 made by trog or exonerate, on the top value of the selector, add this value in a string:
-897.06939697265625
next send that signal to an array limit module made by trogluddite.
Replace the min with the same value in a string:
-897.06939697265625
so next make two floats with these two values:
and
and use all of it as follows
signal--->nan to 0 (edited)--->(0.00109043*signal)--------->(0.978191+signal)--------------> (final result 0-1)
this can be useful for just about anything. You could use it for floats also instead of arrays in a similar manner.
Robert
My youtube channel: DSPplug
Re: better db to linear 0-1 (especially array)
Postby tulamide » Tue May 19, 2020 9:49 pm
That's an interesting approach, but in no way better than the usual
10^(n/20)
## or
10^(n * 0.05)
You're converting strings (this alone takes longer than above calculation), use two code blocks and still multiply and add. It's ok, but not better.
Postby juha_tp » Wed May 20, 2020 7:11 pm
How's exp(0.115129254649702 * n) ?
juha_tp
Postby wlangfor@uoguelph.ca » Fri May 22, 2020 11:29 pm
good feedback thanks, My goal however was to avoid the presence of a zero, other than in the case of a 0dBFS. So as to convert and utilize, which db conversion can miss.
