Flowbotics with CrustCrawler Smart Arm AX-12A
Postby dunkineigen » Tue Mar 20, 2012 10:56 pm
I have a problem detecting CrustCrawler smart arm with Flowbotics Studio.
I use USB2Dynamixel (USB to RS-232 converter) and CM-510 to power the Dynamixel servos.
I am able to use the Bioloid motion software (RoboPlus) with the arm (the arm is detected on COM3).
Should I do something else to detect the arm in Flowbotics?
Kindly let me know.
Thanks.
dunkineigen
Re: Flowbotics with CrustCrawler Smart Arm AX-12A
Postby Embedded » Fri Mar 23, 2012 2:07 am
There is nothing special to do, you just need to select the correct com port for the USB to rs485.
Have you tried the Flowbotics studio example file in the examples folder? This also supports the CrustCrawler arms.
Embedded
cron
