Getting rid of mousepointer (Alpha)
Postby lalalandsynth » Sun Jun 14, 2020 5:13 pm
I used to get rid of the mouse pointer with a ruby window "def mouseCursor 2 end"
This stopped working in the alpha , did anything change and I missed it or is this a bug ?
lalalandsynth
Re: Getting rid of mousepointer (Alpha)
Postby lalalandsynth » Mon Jun 15, 2020 3:17 pm
Using this works .
def isInMousePoint x, y
true
def mouseCursor x,y
2
lalalandsynth
Postby wlangfor@uoguelph.ca » Tue Jun 16, 2020 8:15 pm
Thanks Lala, useful
My youtube channel: DSPplug
Postby trogluddite » Wed Jun 17, 2020 3:59 pm
When isInMousePoint returns false or isn't defined, none of the other mouse methods should ever be called - so what you described is the correct behaviour AFAIK (in an exported plugin, at least). AFAIK, that's how it's always worked - I've made use of this behaviour in quite a few v3.0.x schematics.
cron
