HTTP Post Module Message Box
Hello!
I have a question. The http post module gives me a messagebox with "Port = 80" - Oh well i know that is 80, because i ordered it in the ur with "domain:Port". And it's also working, but everytime i get this nasty messagebox, an if i habe an automated server, this messagebox stops the whole programm.
Is there any way to disenable this Messagebox?
Regards, C.Hackl
Regards, C.Hackl
chackl - Posts: 233
Re: HTTP Post Module Message Box
Yes I have the same thing, but it is only on Windows 7, on XP this doesn't happen.
I think you will find this is nothing to do with FlowStone and is just a Win7 security notice. Maybe if your tuned your Windows security level down it will not appear. Also check your firewall settings?
- DSP
Well also on XP machines her. I get the same message.
If i do it with an older version of Flowstone or with synthmaker i don't get the message. Since flowstone has the changeable port on this module i get this message.
Regards, C.Hackl
Regards, C.Hackl
chackl - Posts: 233
I stand corrected I just tested it on my XP machine and I get the same.
I've emailed support to see if they have a solution.
- DSP
Just had a prompt reply from support, they have a solution and will implement it in the next dot update.
- DSP
Happens on Vista too.
Any news when this is coming?
I'm a SynthMaker user and my only reason for trying FlowStone is because it's HTTPPost component returns date.
I have an idea that requires internet connectivity (preferably UDP or TCP, but HTTP would do for prototyping).
- mvdlee
No idea when the next update will be, but looking at the past release history I would imagine in a month or two.
Do you need a solution urgently?
You can of course always use the Network modules UDP & TCP instead in FlowStone.
- DSP
