[Ruby] Simplest access to a class instance?
Scenario:
3 RubyEdits connected to views, each view displays a part of a whole. There's one class that manages everything, defined and instantiated in the first of the 3 modules.
First Implementation:
I used a class variable for accessing the class instance from all 3 RubyEdits. Works like a charm. However, let me remind you that all instances of a plugin share the same Ruby Interpreter. Therefore, if working with several instances of this schematic, any instance overwrites the class for all other instances as well.
Question:
I tried to use class instance variables instead and send the class instance out via RubyValue. Unfortunately that creates copies of the class instance, instead of letting me access the instance itself. How can I have access to one class instance from all 3 modules, while still have individual class instances per plugin instance? Do I really need to implement a callback system?
Question:
Re: [Ruby] Simplest access to a class instance?
You can create your class as a module. Then create Anonymous class in each plugin and include the module in it. Then send reference to your anonymous class to each ruby-edit in that plugin during startup. This would ensure that each plugin has its own instance of that class.
https://www.mobomo.com/2012/2/using-anonymous-classes-and-modules-in-ruby/
- KG_is_back
Users browsing this forum: Google [Bot] and 17 guests
