Ruby Array Formating
Postby aronb » Fri Mar 17, 2017 5:24 am
I created a Ruby Circle Class that seems to work. I created an array of circles, that seems to work as well... However I don't know how to format the output to an external array in one of two ways. :oops:
1 - With all of the circle data array info in one comma delimited array
2 - With each element in its own array
Here is my schematic, (with notes) any help would be appreciated please :)
Ruby_Circle_Array.fsm
Ruby Circle Array and Class
(1.86 KiB) Downloaded 923 times
Thank You,
Aron
aronb
Re: Ruby Array Formating
Postby tulamide » Fri Mar 17, 2017 12:30 pm
Get all data from one type into an array:
xpos = []
cir.map { |e| xpos << e.xposition }
output 'data', xpos
You'd do the very same to each of your class' values (e.g. e.yposition, or e.color)
Getting an array of arrays is more tricky, since you don't have an array of arrays output. Instead you would translate it to a string and output a string.
Since I don't know what you expect the exported values to be used for, I can't tell more.
Postby aronb » Sat Mar 18, 2017 3:26 am
tulamide,
Thanks - that got me going to the next part! :D !
I almost feel I am FINALLY learning a bit of Ruby :oops: Its a long road when you mind is a bit older :shock:
Aron
aronb
