Multiple views (Ruby)
Postby DaveyBoy » Mon Apr 03, 2017 11:22 am
Hi Guys
The manual (page 156) mentions multiple views but doesn't explain how to use them. In the example below, how would I draw to the bottom view only?
As always any advice much appreciated.
Thanks in advance
Dave
DaveyBoy
Re: Multiple views (Ruby)
Postby TheOm » Mon Apr 03, 2017 5:43 pm
Use the first parameter of draw to distinguish which view is requesting the draw, for example like this:
ruby multi view.fsm
(549 Bytes) Downloaded 990 times
TheOm
Postby DaveyBoy » Mon Apr 03, 2017 7:34 pm
Yes that works
Thanks TheOm :)
DaveyBoy
Postby DaveyBoy » Mon Apr 03, 2017 10:23 pm
Hmmmm now I have another issue:
The mouseover is still active in the top view... any way to stop this?
Multiple Display Mouseover.fsm
(1.96 KiB) Downloaded 995 times
Thanks again in advance :)
DaveyBoy
Postby KG_is_back » Tue Apr 04, 2017 12:26 am
It seems to be a bug. In the mouse-related methods the input ("i") object doesn't work. It always is index 0 by default and empty name (""). While in the draw method it is correctly indexed both by number and by name.
Postby DaveyBoy » Tue Apr 04, 2017 11:20 am
Thanks KG
Seems this has been mentioned before, I was just about to give up when I found this thread:
http://www.dsprobotics.com/support/viewtopic.php?f=2&t=3518&hilit=multiple+view&start=10
So adapting Tronic's "Trigger View" workaround and changing the cursor all is good :D
Multiple Display Mouseover Working.fsm
(2.18 KiB) Downloaded 948 times
It is a bit of a hack but it works!
Hope this will help someone else in the future until the bug is fixed :)
Thanks again KG
DaveyBoy
