Multiple views (Ruby)
Hi Guys
The manual (page 156) mentions multiple views but doesn't explain how to use them. In the example below, how would I draw to the bottom view only?
As always any advice much appreciated.
Thanks in advance
Dave
Thanks in advance
Dave
DaveyBoy - Posts: 131
Re: Multiple views (Ruby)
Use the first parameter of draw to distinguish which view is requesting the draw, for example like this:
- ruby multi view.fsm
- (549 Bytes) Downloaded 939 times
- TheOm
Yes that works
Thanks TheOm
Thanks TheOm
Hmmmm now I have another issue:
The mouseover is still active in the top view... any way to stop this?
Thanks again in advance
It seems to be a bug. In the mouse-related methods the input ("i") object doesn't work. It always is index 0 by default and empty name (""). While in the draw method it is correctly indexed both by number and by name.
Thanks KG
Seems this has been mentioned before, I was just about to give up when I found this thread:
http://www.dsprobotics.com/support/viewtopic.php?f=2&t=3518&hilit=multiple+view&start=10
So adapting Tronic's "Trigger View" workaround and changing the cursor all is good
It is a bit of a hack but it works!
Hope this will help someone else in the future until the bug is fixed
Thanks again KG
Thanks again KG
