Export as VST FX and have midi input.
Postby lalalandsynth » Sun Aug 20, 2017 2:57 pm
Am I missing something here or does midi input not work if you export as VST FX ?
lalalandsynth
Re: Export as VST FX and have midi input.
Postby KG_is_back » Sun Aug 20, 2017 3:49 pm
Yes, it is very simple. VSTi (instruments) must have a midi inputs only. If the plugin has a mono stream input it is automatically a VST effect, even if it additionally has midi input. You can turn any VSTi schematic into VST effect by adding dummy mono output to them.
