PPQ Position And Poly Readout
How do you read the Host position using the PPQ Position component ? I attached the poly readout to the PPQ Position but there is no output. Any ideas ?
- DSPRU1
Re: PPQ Position And Poly Readout
PPQ Pos is dependend on a MIDI host. Flowstone isn't. If you want to read out PPQPos, you need to compile a plugin and test it in your DAW.
Users browsing this forum: No registered users and 102 guests
