FX slots question.
• Page 2 of 2 • 1, 2
Re: FX slots question.
Thanks , I was wondering if there is a way to get rid of the gray popup that is common with all these?
lalalandsynth - Posts: 600
if you want to use my fx order it is not possible to use the same fx several times, also the reordering would not make much sense then.
if you want all your fx on each slot you need to have them multiple times, with selectors everything which is not in use doesn't need cpu so it would not be too bad to have them multiple times.
anyways here is a fast hack to use a bitmapstrip for the fx order module with 4 fx.
- fx order using bmp.fsm
- (136.91 KiB) Downloaded 806 times
Nubeat7 - Posts: 1347
