First (Not Last) Function - Stream & Green
Postby guyman » Sat Nov 02, 2019 1:07 am
This one can be seen a few ways. It is the inversion of the "Last" prim. It outputs not the last input that was changed, but rather the one that didn't change. So it's not a "changed" gate, but a gate that allows an input through that isn't dynamic. It could also tell you who won a race, when a race is over. Send two inputs into it, whatever arrives at a "stop" first will pass through, after the runner up arrives. So it could be used to construct a goal task, or a float delay.
What else?
I'm having a crack at simple peculiar "novel" modules this week after months of building a spaceship. Please join.
First (Not Last) Function - Stream & Green.fsm
(8.49 KiB) Downloaded 997 times
guyman
Re: First (Not Last) Function - Stream & Green
Postby Spogg » Sat Nov 02, 2019 12:29 pm
Good stuff Guyman!
As before, these went into my toolbox, so thank you for making and sharing these unusual things. :D
Postby kortezzzz » Sun Nov 03, 2019 5:07 am
Straight to toolbox! Thank you 8-)
kortezzzz
