Ultimate crash code!!!
Postby KG_is_back » Sun Mar 23, 2014 2:02 am
I have found a way to ultimately crashing schematic.
Following code will instantly crash application once it is activated. It is due to a fact that memory address [0] is reserved as a special value for "no address defined". If you try to load form that space schematic instantly crashes.
streamout out;
mov eax,0;
fld [eax];
fstp out[0]
When you use it in poly section the code is executed when voice is created. You can therefore create a code that crashes the application on order. It might be useful for a "prank" VST that crashes a daw once you hit a button. Or even better for registration protection in your plugins and apps that will ultimately prevent user form using certain features of the program unless registered.
code_crasher.fsm
(1.32 KiB) Downloaded 1114 times
KG_is_back
Re: Ultimate crash code!!!
Postby tester » Sun Mar 23, 2014 2:12 am
Good one. :mrgreen:
Until they fix it in FS. :-)
tester
Postby KG_is_back » Sun Mar 23, 2014 2:18 am
tester wrote:Good one. :mrgreen:
that's the cool thing about it - it is unfixable. The code would have to check the address every time before fld [eax]; gets executed - it would have to automatically add lines to your assembly code which is generally a very bad idea in the first place (it would kill the point of assembler prmitive, as it would "unoptimize" your every schematic). It works in C++ and every programing language too - ULTIMATE CODE-CRASH!!!
KG_is_back
Postby KG_is_back » Sun Mar 23, 2014 2:33 am
A little fun improvement xD
code_crasher.fsm
(1.46 KiB) Downloaded 1124 times
KG_is_back
