Serum like waveform animation
Hi gang !
For a project I would like to be able to create the same animation as that visible in the Serum synthesizer on waveforms, when a MIDI keyboard key is pressed. Example: https://www.youtube.com/watch?v=gKr6Ux_1TcE (from 3:23).
I think this animation is possible in the "DrawWave" module of a sampler, multisampler or any element that displays the waveform. Can one of you give me a track to be able to do this with, if I do not ask for too much, some examples in the form of * .fsm file? That would be very nice of you !
And sorry for this English, i'm French.
In advance, thank you for your answer !
- az-terisk
Re: Serum like waveform animation
I'd like to make a synth with the same effect so I will try and do this!
in a month at most I hope.
Hello,
On my side I found a trick: display a "scope" as soon as the note is pressed, then go back to the static waveform once the key is released. If you ever...
- az-terisk
