Sample Recorder Schematic
Hey Guys
Just want to say, please excuse the noob work in this schematic, i'm still learning, and a lot of the stuff is made up of elements I have found on this forum, and I changed them a bit.
I am trying to get this schematic to record the input straight into the sample loader, without having to save it and load it in between? I wonder if that is even possible?
Also I am trying to link the Pitch (Green - Float) onto and LFO (White - Poly), any suggestions would be great
SAMPLE RECORDER1.fsm- (242.15 KiB) Downloaded 1243 times
- glitchcpt
Re: Sample Recorder Schematic
Yes, you can. Simply connect the wave connector from mem-create prim directly to wave player (to the interpolated read module).
EDIT: in order to make it work with loaded files too, you will have to use selector to switch between loaded wave file and mem-create wave.
As for the pitch. It should work to directly connect green to any stream - be it blue or white.
Thanks KG!!
Let me try if it works
I usually get it working Green - Poly, but in this instance its the other way round, Poly - Green, is there a way of capturing the data in bits, into a float? (excuse me for not explaining it very well)
- glitchcpt
There is poly to array prim that may be able to do this. it captures first 2048 samples from each voice or something. I never used it though.
Ok! Thanks man, it seems to work with the M2F primitive
I can't manage to get the sampler record function to work yet tho
- glitchcpt
This is exceptionally decent and wonderful post.
I am very happy joined this forum.
I like it exceptionally much....!!!!
Thanks alot...
Thanks alot...
Sumer
- Sumeraxe
