Keypressed Example with 2 and 3 keys - ordered
1 post
a small example for using the "keypressed" primitive with 2 or 3 keys .
can be helpfull when using hotkey-combinations like "CTRL+A" or "CTRL+ALT+A" in your project.
just select the keys you like to use from the dropdown menu.
NOTE: this example will ONLY work if the keys are pressed in right order!
i hope somebody will find it usefull. cheers
vKEy Combine ordered by philton.fsm- keypressed with 2 or 3 keys by philton
- (8.31 KiB) Downloaded 1669 times
- philton
1 post
