Clip indicator
Clip indicator
Postby Alexandre » Fri Feb 14, 2020 2:18 am
EDIT: improved version below (post number 10)
clip detect.fsm
(26.03 KiB) Downloaded 1493 times
Alexandre
Re: Clip indicator
Postby wlangfor@uoguelph.ca » Fri Feb 14, 2020 9:09 pm
Thanks Alex :)
My youtube channel: DSPplug
Re: Clip indicator
Postby Alexandre » Sun Feb 16, 2020 2:13 am
Glad one of the pro's looked at it :)
Alexandre
Re: Clip indicator
Postby wlangfor@uoguelph.ca » Sun Feb 16, 2020 8:12 pm
Oh yeah, I'm into anything; I want to use this and will giver credit? is that OK? sending you a free copy of My EQ :)
Re: Clip indicator
Postby Alexandre » Sun Feb 16, 2020 9:26 pm
Thanks, looks like a VERY nice EQ :)
I just noticed that the clip indicator has problems, for instance if you crank up the gain with sinewaves. Looks like it will hang with a lot of clipped samples. I´m not sure what´s happening. Maybe you can fix it?
Alexandre
Re: Clip indicator
Postby wlangfor@uoguelph.ca » Mon Feb 17, 2020 7:35 pm
Alexandre wrote:Thanks, looks like a VERY nice EQ :)
it's set to use less triggers but I can try and make it faster.
It's a good suggestion, thanks. I did not filter the signal to the analyzer with a dc offset correction because I prefer to see the real bulge from the bass. I have a more recent analyzer model that I used for the Freq EQ, perhaps it'd be better for it.
Thanks
Re: Clip indicator
Postby Alexandre » Mon Feb 17, 2020 11:27 pm
I was talking about MY "clip indicator":
Alexandre wrote:I just noticed that the clip indicator has problems, for instance if you crank up the gain with sinewaves. Looks like it will hang with a lot of clipped samples. I´m not sure what´s happening. Maybe you can fix it?
This was NOT about your EQ! I have nothing but praise for that!
Sorry for the bad communication (I thought it was obvious...)
Alexandre
Re: Clip indicator
Postby wlangfor@uoguelph.ca » Tue Feb 18, 2020 8:18 pm
Oh, well I did some testing and improved it nonetheless.
I'll be adding and LU average line inidicator on a horizontal grade as well as true peak indicator on a thin horizontal as well as mid and low average to better guage highs and lows. I'll probbaly end up using your example as a way of resetting things dynamically.
I will send you a private schematic for you to maybe get some pointers from OK? But it is commercial and private. Thankyou for respecting that in advance. I have no problem with you using, but please ask before sharing if public :).
My governor product was a good start and perhaps a better alternative to vocal/gain riding. At least once it is efficient enough. It used three passes of a mean averaging algo. Now it should only use one mean average and a more conventional gain riding technique to set the volume appropriately.
It gave me an excuse :)
Oh, and BTW; I perfected My method for controlling things with the mousewheel. I figured a way to make it a bit simpler so that it is a single small module to copy and paste.
I will post that up very soon.
Re: Clip indicator
Postby Alexandre » Wed Feb 19, 2020 2:33 pm
Thanks, I´m honoured! Can´t devote time to this right now, but I´ll come back and learn from your schematics and others here. This is a nice community. :)
Alexandre
Re: Clip indicator
Postby Alexandre » Thu Jun 15, 2023 8:15 pm
This is improved and better explained (better comments)! Works well with FlowStone alpha.
clip_ind.fsm
(35.14 KiB) Downloaded 565 times
Alexandre
