Key Pads for Touchscreens
Hello all,
More 2 useful Tools i wil share with you
One Alpha and one Numeric KeyPad for string and Num entries.
its good for use as Filename or Numentry in Touchapp for Synthesizer or other FlowStone App's
Is Contrlable Window for automatic Hiden by Selectpin
Is Witen by "FlowStone 3.0.8" and Testet with 3.09
Happy to Use
Greeting Pali64
Happy to Use
Greeting Pali64
- AlphaKeyPad.fsm
- "FlowStone 3.0.8" Alpha TouchPad(Capital Letter)
- (156.67 KiB) Downloaded 1368 times
- NumKeyPad.fsm
- "FlowStone 3.0.8" Numeric TouchPad
- (52.87 KiB) Downloaded 1368 times
We made Keyboard and Synthesizer for you
so all Poaple can kommunicate with a Language to all poaple understand
Music is the nicest work in World
Pali64 - Posts: 22
Re: Key Pads for Touchscreens
Very clever!
I like that I can go inside and configure the keys with whatever character I want.
Thanks for sharing!
Thanks for sharing!
Spogg - Posts: 3326
Great...keep up the good work
sheepadoodlepeekapoocannabinoidhyperemesissyndromecleidocranialdysplasia
- Markk786
Hello all,
a Modifyred useful Tools i wil share with you
The Alpha-KeyPad for string entries.
its good for use as Filename or Touchapp for Synthesizer or other FlowStone App's
Is contrlable Window for automatic Hiden by Selectpin or as an Standalone EXE File with self-ending-Futures after te [ENT] Key was pressed or the Srver ist Terminateed.
New Futures:
1) The Keyboard can Kommunicate as anClient over Network (Use the Servermodule in you Applikation.
This is idealy to use as an Standalone EXE Program what Startet from your own software over the EXE plug-in
from Flowstone
2) Al keys are Konfigurable over the Property Window
3) The Keyboard has a Caps and Capslock funktion for free settable different keys
The Caps made selv reset after a Key is Pressed the Capslock holds until you press the [capslock] again or one of the two [SHIFT] key's
The kys has in this Variante Commands wich kan controlled it:
Send over the Server an "{TXT}........" command to place the Entryselect String on Leftside to Display.
Send over the Server an "{STR}........" command to place the Devault_Entry-String on Entrywindow.
Send over the Server an "{KEY}........" command to use as an Future Insigt on the Key-App
Send over the Server an "{PWR}1" command to ending the Key-App from your Applikation
After the Keyapp was Startet it send you over the Serverapp the String "{Mix}1" to tell you the app was Started and Online
Happy to Use
Greeting Pali64
New Futures:
from Flowstone
Happy to Use
Greeting Pali64
- AlphaKey_V0_2.fsm
- (309.83 KiB) Downloaded 1171 times
Pali64 - Posts: 22
I made a post regarding making a universal system and rule for knobs and sliders. That would mean ideally that there would be a port of Your
schematic for touch screen support (with attribution); Is that OK?
LINK: http://flowstone.co.uk/support/viewtopic.php?f=4&t=13565&....
I figured it'd be great if We had a system like Voxengo, Waves worked out with available schematics to make it an easy thing.
I came up with a new version that is the prequel to standardized slider/knob controls with touchscreen and tooltip / help window support.
Let Me know if this is acceptable Use and please let Me know if My using Your example to this end is OK; and I'll make the rest
And here is the schematic:
BTW Pali, how do I make square links to modules? Can You tell me how?
Hi Pali, I made a new version which adds machine logic and adds numbers only within a range.
http://flowstone.co.uk/support/viewtopic.php?f=3&t=13634&sid=5ad79d6613ef7ea41b3724ae841e7285
Users browsing this forum: Google [Bot] and 17 guests
