WinOS Version & 32-64 bit Architecture Finder - Ruby
This is the Ruby version of Windows OS Version & 32-64 bit Architecture Finder v1.0.0. I have tested it on Windows XP 32-bit and on Windows 7 64-bit. It would be kind if someone can test it on Windows 8 & Windows 2000 and perhaps on Windows XP 64-bit as well and give feedback thereon. Thank you in advance.
WinOS Version & 32-64 bit Architecture Finder - Ruby v1.0.0.fsm- (2.08 KiB) Downloaded 1224 times
tiffy - Posts: 400
Re: WinOS Version & 32-64 bit Architecture Finder - Ruby
it says windows 7 64 bit while im running windows 8.1 pro with media pack 64 bit.
PM me if you are interested.
CoreStylerz - Posts: 327
CoreStylerz wrote:it says windows 7 64 bit while im running windows 8.1 pro with media pack 64 bit.
Thank you for your feedback CoreStylerz, then I will have to remove the Schematic and revert to the version made with DSP Robotics components as I have read in the meantime on other Forums that 'RUBY_PLATFORM' instruction, which is what I have been using here, is not a reliable method to determine OS Versions.
tiffy - Posts: 400
just to keep feedback coming in ..
On my WinXP-32 the module displays: OS: Windows 32bit
