Linear equation matrix solver
• Page 2 of 2 • 1, 2
Re: Linear equation matrix solver
The solver actually calculates the matrix size from the "no. of equations" input, So the code will ignore values if you input too long array. Internally the max buffer size is set to 200 (so 13equations max) but you can easily increase the maximum within the code by simply setting all the float arrays bigger.
- KG_is_back
Pure Ruby Gaussian elimination
# Performs an in-place Gaussian elimination on an NxN matrix 'matrix' (2D array
# of Numeric objects) and an N-element vector 'vector.' (array of N Numerics).
def gaussianElimination(matrix, vector)
0.upto(matrix.length - 2) do |pivotIdx|
# Find the best pivot. This is the one who has the largest absolute value
# relative to his row (scaled partial pivoting). This step can be omitted
# to improve speed at the cost of increased error.
maxRelVal = 0
maxIdx = pivotIdx
(pivotIdx).upto(matrix.length - 1) do |row|
relVal = matrix[row][pivotIdx] / matrix[row].map{ |x| x.abs }.max
if relVal >= maxRelVal
maxRelVal = relVal
maxIdx = row
# Swap the best pivot row into place.
matrix[pivotIdx], matrix[maxIdx] = matrix[maxIdx], matrix[pivotIdx]
vector[pivotIdx], vector[maxIdx] = vector[maxIdx], vector[pivotIdx]
pivot = matrix[pivotIdx][pivotIdx]
# Loop over each row below the pivot row.
(pivotIdx+1).upto(matrix.length - 1) do |row|
# Find factor so that [this row] = [this row] - factor*[pivot row]
# leaves 0 in the pivot column.
factor = matrix[row][pivotIdx]/pivot
# We know it will be zero.
matrix[row][pivotIdx] = 0.0
# Compute [this row] = [this row] - factor*[pivot row] for the other cols.
(pivotIdx+1).upto(matrix[row].length - 1) do |col|
matrix[row][col] -= factor*matrix[pivotIdx][col]
vector[row] -= factor*vector[pivotIdx]
return [matrix,vector]
# Assumes 'matrix' is in row echelon form.
def backSubstitution(matrix, vector)
(matrix.length - 1).downto( 0 ) do |row|
tail = vector[row]
(row+1).upto(matrix.length - 1) do |col|
tail -= matrix[row][col] * vector[col]
matrix[row][col] = 0.0
vector[row] = tail / matrix[row][row]
matrix[row][row] = 1.0
# Example usage:
# A system of equations: matrix * X = vector
matrix =
[1.0, 1.0, 1.0, 1.0],
[0.0, 1.0, 2.0, 3.0],
[1.0, 2.0, 4.0, 8.0],
[0.0, 1.0, 4.0, 12.0],
vector = [1.0, 0.0, 2.0, 0.0]
# Create a backup for verification.
matrix_backup = Marshal.load(Marshal.dump(matrix))
vector_backup= vector.dup
# Gaussian elemination to put the system in row echelon form.
watch 'gaussian matrix', matrix
watch 'gaussian vector', vector
# Back-substitution to solve the system.
watch 'back matrix', matrix
watch 'back vector', vector
# Verify the result.
pass = true
0.upto(matrix_backup.length - 1) do |eqn|
sum = 0
0.upto(matrix_backup[eqn].length - 1) do |term|
sum += matrix_backup[eqn][term] * vector[term]
if (sum - vector_backup[eqn]).abs > 0.0000000001
pass = false
break
if pass
watch "PASSED?", "Verification PASSED."
else
watch "PASSED?", "Verification FAILED."
digitalwhitebyte - Posts: 106
Came back to a solved problem
Find it easy to apply, hard to understand. Was wondering if one can find X, couldn't X then be solved by integrating it on a loop. Or..?
192k @ 8ms
MegaHurtz - Posts: 105
