The Quilcom UNISON: explore the sound of unison oscillators
Re: The Quilcom UNISON: explore the sound of unison oscillat
Postby tulamide » Sat Dec 12, 2015 7:30 pm
Thanks once again, Martin. You helped me make a decision which filter to use.
And Spogg, sorry for derailing your thread :oops:
Postby Ricciardo » Fri Jan 08, 2016 3:11 pm
Great unison sound!
Ricciardo
Postby Spogg » Sun Mar 29, 2020 12:03 pm
I was asked if I could make this compatible with the FS4 alpha so I have! Going back to this was a real blast of nostalgia (and embarrassment!). But it still sounds good at least.
If anyone wants an old Quilcom to use in FS4 because it doesn’t work, please just ask.
The fix was down to changing xmm41 to xmm4 in the ADSRs ASM code. I made extensive use of this excellent envelope generator (by Martin Vicanek) before FS4 found the error, so you can easily change this yourself. The symptom is no sound.
https://www.dropbox.com/s/sttetlo8inicg ... 1.zip?dl=0
The above link is to a zip which contains the FSM (3.06) and 32 & 64 bit exports (both made in FS4).
Original post also updated.
Postby martinvicanek » Sun Mar 29, 2020 1:08 pm
:oops:
Postby RJHollins » Sun Mar 29, 2020 6:39 pm
Hi Spogg.
Are you able to make VST-3 [64] of FS projects ???
Postby Spogg » Mon Mar 30, 2020 8:15 am
RJHollins wrote:Hi Spogg.
Yes the FS4 alpha has the possibility of exporting VST-3 64 bit but I haven’t tested it yet. I think I maybe should!
Previous
