1x to 2x to 4x Sawtooth
Postby BobF » Wed Oct 10, 2018 4:18 pm
Bobs1x2x4xSaw.fsm
(416.85 KiB) Downloaded 1036 times
Hello gang,
Back to some easy stuff! Here is a simple 1x to 2x to 4x Sawtooth multiplier/waveshaper module for your tool box. It can be used for your SUPER SAW's and also works as a wave shaper for sine, triangle, and parabola. A modulation input is also included.
I really like creating modules like this, I guess it's the challenge. The thought of how you can take this static wave shape and make it into another useful shape. Maybe some more as I can dream them up.
Comments always welcome!
Later then, BobF.....
BobF
Re: 1x to 2x to 4x Sawtooth
Postby adamszabo » Wed Oct 10, 2018 9:02 pm
I like the concept, however its should be called Saw Octaver than a supersaw creator. In a supersaw the saws are the same pitch, only detuned slightly from each other, however this module add a saw on each octave. It could be interesting to multiply this thought and create an octaver supersaw. Now that would be interesting!
adamszabo
Postby lalalandsynth » Wed Oct 10, 2018 9:30 pm
Testing this . :)
lalalandsynth
Postby Halon » Wed Oct 10, 2018 9:39 pm
Thanks Bob :)
Halon
Postby Spogg » Thu Oct 11, 2018 8:15 am
Interesting idea Bob (as always!). :ugeek:
The issue I saw and heard is with the green part used to switch over the selectors.
I think it would be much improved if all the control could be done in the audio stream. Then you could have LFO or even audio rate modulation without the clicking.
I like the range you get from using a sine wave especially, so I think it would be worth the effort.
Postby BobF » Thu Oct 11, 2018 10:33 pm
Bobs2x4xSaw rev2.fsm
(914.64 KiB) Downloaded 1034 times
Hello gang,
Here is my best solution! Let me know what you think.
Thanks, Bob.
BobF
Postby Spogg » Fri Oct 12, 2018 8:28 am
SO much better Bob! And done so quickly!
Well done mate, and thanks for sharing it.
Postby Halon » Fri Oct 12, 2018 9:10 pm
Thanks again Bob :)
Halon
