Working Example: (Unpretty) Sub Bass
Postby wlangfor@uoguelph.ca » Thu Feb 07, 2019 3:10 pm
So, sub-bass.
I made My first synth. Under 1% CPU - But spikes to 2% when processing. Perhaps a LP would change that.
Used a few examples including those by Martin Vicanek, Acrobat, Trogluddite, Dozius and possibly MvdLee.
I also mentioned the contributors of the knobs in the file. This working example I made within the FL Studio flowstone version and detects velocity, pitch and midi notes. It's nothing fancy.
References:
The one by freepik.net I think is OK commercially, but You'd have to research. It's My go to knob from now on in. You can look at the original here:
https://www.freepik.com/premium-vector/realistic-round-silver-button-with-silver-frame_2049796.htm
(just so You know I use the rotate primitive and a star ellipse gradient in gray two tone to emulate a recessed knob pointer)
And for the other one, it's referenced from the Pandora UI Kit found Here:
https://designmodo.com/pandora-free/
Anyways, Should You want knobman versions of these files (made by Me) You can Download them (CCBY).
Download (CCBY): LA School Sub Bass V2 9.fsm
LA School Sub Bass example
(114.25 KiB)
My youtube channel: DSPplug
Re: Working Example: (Unpretty) Sub Bass
Postby djbrynte » Sun Feb 17, 2019 10:00 pm
nice knobs
djbrynte
Postby djbrynte » Sun Feb 17, 2019 10:01 pm
where is the synth?
djbrynte
Postby wlangfor@uoguelph.ca » Thu Feb 21, 2019 3:03 pm
djbrynte wrote:LA School Sub Bass V2 9.fsm
it had been at the bottom of the post
(114.25 KiB)
https://web.archive.org/web/20190207141138if_/http://www.flowstone.co.uk/support/download/file.php?id=8495&sid=6898609b4d929097899b2b28293c9586
djbrynte wrote:nice knobs
Not bad eh?
About the knobs though; Technically they're an original creation, the illustrator had obviously taken tutorials and whatnot and used generic examples. So; i guess My knobman file is original but nonetheless; If You use these knobs commercially; You should probably pay the small fee to freepik.net. Alas, I am not a re-distributor; So everyone would have to get a license commercially. But then again, it might be free. But less headaches if You go the right route in the end.
Anyways, in regards to this synth: I made it originally but there are quirks with the realtime playing but not midi. So I looked to the SMG examples and made something that works a bit better. I did'nt have time to attend to that but will.
here's something else I'm making with those knobs:
It's a port of a compressor someone from this board made and I wanted to make an example with the animated envelope and threshold triangle in a working example so that people could throw one together easily.
Postby wlangfor@uoguelph.ca » Fri Mar 29, 2019 2:42 pm
So, working with the AMVST code I was able to make a better version of this that has no bugs in the midi section and doesn't mind fast realtime play.
Coming soon.
