Trouble with poly stream. Could someone help?
Postby Halon » Sat Sep 28, 2019 10:05 am
Hi.
Im having trouble connecting the poly stream to the combiner in my synth project. Ive tried many things, even copying every module into a new schematic but nothing.
Could someone have a look?
Thank you.
Halon
Re: Trouble with poly stream. Could someone help?
Postby Phil Thalasso » Sat Sep 28, 2019 12:35 pm
Hello Halon,
the problem lays with the displays.
I once did a filterbank in which I had to replicate the generators per display.
Have a good week-end and thank you for all your good work.
Best regards
Phil
Poly stream problem_Phil.fsm
(1.75 MiB) Downloaded 941 times
Phil Thalasso
Postby Halon » Sat Sep 28, 2019 6:04 pm
Thank you so much Phil! Have a good weekend youself :)
Halon
