Ruby problem?
Ruby problem?
Postby adic » Fri Oct 30, 2015 1:03 pm
Hello,
I made an example of Ruby animation on FS 3.06, which does not work for some reason on the latest version 3.08.1 (trial). Have DSProbotics perhaps changed the specification of Ruby's draw method?
So long
circle_lfo.fsm
this schematic works well on FS3.06 but does not work on FS3.08.1
(14.9 KiB) Downloaded 973 times
adic
Re: Ruby problem?
Postby KG_is_back » Fri Oct 30, 2015 1:41 pm
The problem is, variable @x now by default references the current Thread. Unfortunately you cannot use it. Just change it to some different name and everything should be OK
Re: Ruby problem?
Postby adic » Fri Oct 30, 2015 3:19 pm
Hello, KG
I've replaced the variable names (@x -> @x1) as you told and the schematic is working well on the latest version 3.08.1.
thank you.
circle_lfo_v2.fsm
corrected version
(15.36 KiB) Downloaded 961 times
adic
