Separators in menus
Separators in menus
Postby az-terisk » Fri Aug 07, 2020 9:57 pm
Hi gang !
How can i add separators in the menus, please ? Like Adam Szabo's Viper main menu : https://image.noelshack.com/fichiers/2020/32/5/1596834020-capture.png
Thanks !
az-terisk
Re: Separators in menus
Postby adamszabo » Sat Aug 08, 2020 9:18 am
That is possible in the alpha versions only
adamszabo
Postby az-terisk » Sat Aug 08, 2020 10:21 am
adamszabo wrote:That is possible in the alpha versions only
Hello Adam, i'm an user of Alpha version ! :)
az-terisk
Postby adamszabo » Sat Aug 08, 2020 10:39 am
Then you can write this string in the dropdown list to create a line between item 3 and 4: "Item1, Item2, Item3, -----, Item4" and you will get the separator. Just watch out because the separator still counts as a value, but you cannot click on it. So like this:
Item1 will output 0
Item2 will output 1
Item3 will output 2
(the separator will output 3 but you cannot select it)
Item4 will output 4
adamszabo
Postby az-terisk » Sun Aug 09, 2020 8:31 am
Many thanks to you Adam, i will made it ! :)
az-terisk
Users browsing this forum: No registered users and 68 guests
