Quilcom SIM-THROAT: Don't hurt yours!
Recently I got interested in throat singing in its various forms. Since I already own the instrument I thought I’d have a go at actually doing it.
Apart from failing totally, I hurt my throat and it took 2 days to get better. So I had the idea to make a vocal processor effect plugin to simulate the sounds using my regular voice with a microphone.
The results are far from convincing but may have a novelty value in their own right. After all, brass settings on a Minimoog don’t sound exactly like brass but the sound does get used.
I won’t repeat the details in the User Guide or background info folder, but I’d like to thank Martin Vicanek for his remarkable Vocoder DSP/ASM (and all his other stuff I regularly use).
Download:
https://www.dropbox.com/s/tjezcj1xdlafl ... 1.zip?dl=0
Video:
https://youtu.be/no2VigBumXw
Download:
Video:
Spogg - Posts: 3327
Re: Quilcom SIM-THROAT: Don't hurt yours!
Very cool and interesting, thanks to share !)
I've done some throat singing as autodidact,
after learning a bit of normal singing.
Could not teach but i would say that the base to not be hurt for me
even more with throat singing is to never force anything.
I don't try to go higher or lower, but it must come naturally with no effort at all, expulsing air slowly.
I don't try to be just or even to make a good sound.
Sometime the first time i go to a frequency / resonance it will sound bad but i don't try to do better.
Next time i try it will probably sound better.
Well you don't need it anymore for the sound,
but i like to think that it could have some spiritual or regenerative properties
- Tepeix
